May 12, 2023 at 12:39 pm
Julen
SubscriberHello Everybody,
I set up my Simulation and I got the following error message:
"The problem Preprocessors has not converged."
Yet I don't get any recommendation what to do next or any indication on where the problem might be in the Listing viewer. Does anybody know where I can find some input on where to look or is this common?
May 12, 2023 at 1:12 pm
Ansys EmployeeMaybe elaborate on which solver and what you were doing at the time?
May 15, 2023 at 8:42 am
Julen
SubscriberHello,
I am using Ansys Polyflow and I am trying to model the way a polymer melt flows through a heat sink. I can't really tell you much more, the Listing Viewer doesn't give me much to work with.
I will try to change some parameters and hope it works. Its trial and error from here I think. -
May 15, 2023 at 10:03 am
Ansys EmployeeI'm not sure with Polyflow. Check the model settings, mainly boundary conditions and material properties.
May 15, 2023 at 10:11 am
Julen
SubscriberThank you, I will start there.
May 16, 2023 at 3:11 pm
Julen
SubscriberHello Rob,
the Simulation I was asking about earlier started working, now I am on to the next iteration and I get the following error, do you know how I can fix it, or at leat tell me where to look. I am new to this, and I am trying as hard as possible to learn! Thanks in advance.
*** Starting Step 1 ***
Parameters and Fields | Progress bar(s) |
Evolution parameter S = 7.5500000E-01 |> |
Parameter fac = 5.4328477E+04 |> |
Parameter expom = 1.0000000E+00 |> |Preprocessors
Convergence assumed : Rel. var. LT 1.00000E-03
F.E.M. Task
Divergence detected for field VELOCITIES: iterations cancelled by Expert SystemDivergence of influent solver occurred !
*** WARNING *** from [EVOLUT]
First step does not converge
It is not possible to start the evolution scheme*******************************
* Summary of the simulation *
*******************************The computation failed.
* Expert tool diagnostics *
*****************************The problem F.E.M. Task has not converged.
This is the Error message I get in the Listing viewer. I don't really understand why it has a problem with the evolution parameters. I got a failure earlier and I set them to exactly what the Expert System recommended...
Julen
May 16, 2023 at 3:15 pm
Ansys EmployeeI don't, but the error is divergence related. I've reminded our internal team.
May 17, 2023 at 6:37 am
Julen
SubscriberThanks. Do you know how much time they might need?
Also, I've changed some parameters and run it again. I get the exact same message except one additional thing:
*****************************Out of convergence disk.
May 17, 2023 at 10:33 am
Ansys EmployeeIt's more when the US find their Polyflow specialist.
May 24, 2023 at 3:29 pm
Prashanth
Ansys EmployeeHello Julen
So, what kind of problem is this? On which parameter you are applying evolution? What is your evolution settings?
May 25, 2023 at 6:18 am
Julen
SubscriberHellor Parshanth,
I fixed the problem, thanks for asking though.
I have a different question:
I am trying to simulate the flow of a polymer melt inside an extruder and I need to impose a certain pressure on the outflow (roughly 60 bar). There doesn't seem to be an option to impose a pressure on the outlfow. How would you suggest I fix this problem. Will Polyflow automatically calculate the pressures in the extruder up to the inflow? I am using an imposed volumetric flow rate, so there shouldn't be any reversal of the flow.
I don't expect you to give me the solution, but maybe enlighten me on how to approach this whole problem.
Thanks in advance
May 25, 2023 at 10:13 am
Prashanth
Ansys EmployeeYou cannot directly impose pressure values, you can impose suitable normal velocities at inlet and oulet at that pressure conditions.
5454
3417
2473
1310
1022
