March 9, 2023 at 6:32 pm
javat33489
SubscriberI am modeling two teeth that slide over the rubber. I'm using the Ogden model that I made after testing the material. Axisymmetric solution
But after a 2 mm pass there is always an error, regardless of any grid, any type of contact, and in general any advanced settings:
Settings:
Help or advice please? I also tried using NEQIT, 50, as I move my teeth 15mm and simple steps may not be enough, but it didn't help.
I have also attached the ARCHIVE
March 9, 2023 at 7:05 pm
SubscriberPlease reply with the version of Ansys you are using, Year and R#
March 9, 2023 at 7:33 pm
javat33489
Subscriber2022 R2
March 10, 2023 at 2:33 am
SubscriberI turned on Friction and made some other adjustments, but there is a point in the Static Structural simulation where a dynamic event occurs.
In one increment, the material is here:
In the next increment the rubber has jumped to the left, releasing a lot of strain energy, and the solver cannot find Static Equilibrium again and stops.
The corrective action is to solve this in a Transient Structural or Explicit Dynamics solver.
There is a method you can enable the Static Structural solver called semi-implicit to automatically switch to the explicit solver to solve the dynamic part of the solution and later to switch back to Static Structural. That might be worth trying here, but note that the material should have a density material property because there must be mass to compute a dynamic solution.
The small cylindrical face on the rubber part at the tip may be contributing to the dynamic event. If the conical surface were to continue all the way to the flat top of the rubber, with a small blend on the corner, that might improve the solution.
March 10, 2023 at 5:17 pm
javat33489
SubscriberThanks a lot! I will try!
March 10, 2023 at 5:36 pm
SubscriberTry the geometry edit first. I just tried the Semi-Implicit method using defaults for all parameters and it failed to advance the solution.
March 10, 2023 at 5:43 pm
javat33489
SubscriberOk, I'll try. I'll let you know the decision here
March 10, 2023 at 5:48 pm
javat33489
Subscriber- I will try to solve the problem in Transient Structural.
- I will try Semi-Implicit method in Static Structural.
I'll let you know the decision here.
March 10, 2023 at 6:04 pm
SubscriberI tried the geometry edit in Static Structural and it didn't help. It is the stick-slip behavior of the rubber that makes it a Transient solution.
March 10, 2023 at 6:33 pm
javat33489
SubscriberOk, thanks a lot! I'll try.
March 10, 2023 at 10:03 pm
SubscriberDon't forget to add Damping to the Transient Structural model. I forgot and you can see what happens, lots of high frequency vibration on each stick-slip event.
March 11, 2023 at 10:39 am
javat33489
Subscriberwhat damping factor would you recommend? Or find it by testing?
March 14, 2023 at 6:59 pm
March 14, 2023 at 8:51 pm
SubscriberIs it possible that the contact has Trim Contact enabled? I would delete the contacts and recreate them from scratch.
You could also try Explicit Dynamics. In the video below, the body-interactions are frictionless. I also removed the frictionless support on the right end of the rubber since that is not present in the full model. After I played this animation, I plotted normal stress in the Z-axis which is Hoop Stress, but did not see a compressive stress building as the rubber moved closer to the axis of revolution, so now I want to investigate why that is. You may want to do a small test for yourself before you spend a lot of time on this solver.
March 16, 2023 at 3:33 pm
March 16, 2023 at 5:28 pm
SubscriberTry to solve it without the frictionless support on the right end. Does it escape?
The animation looks better if you color the elements by Body Color, in my opinion.
March 16, 2023 at 6:42 pm
javat33489
In life, there is just an emphasis for her so that she does not run away. If you remove it, I think it will run away. I'll try, the calculation time was 10 hours.
Yes, I was in a hurry. If there is time I will do the color of the bodies. Thanks for the help!
March 16, 2023 at 8:10 pm
Subscriber-
March 17, 2023 at 6:13 pm
javat33489
SubscriberI have not been able to solve it completely yet, after a long time solving the grid error 99999999, I am working on it
March 24, 2023 at 8:14 pm
3744
2573
1809
1236
594
