LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
The problem with implicit analysis
    • javat33489
      Hi all.
      I solve the problem of drilling an SPG ram and it is successfully solved in an explicit solver.
      When I enable implicit analysis I get the error:
      Why?
      ___
      I use cards:
      Thank you.
    • Ram Gopisetti
      SPG is not supported in LS-Dyna,
      there is a version if SPG called as ISPG, but it is tailored for applications involving fluids and gels.
      Cheers, Ram
      • javat33489
        Thank you, I understand you. I will use SPH particles for drilling.
    • Ushnish Basu
      To clarify, SPG is implemented only for explicit analysis in LS-DYNA
