June 13, 2023 at 7:57 pm
javat33489
SubscriberHi all.
I made a composite in the material designer and the calculation on the test model through static analysis and ACP.
I have a mistake in ACP:
My course of action: I made and material steel + PVC:
This is the result:
Next, I made a shell cylinder and set up one layer in ACP:
Next, I made a calculation in static analysis:
Next, I transferred the result to ACP POST. To check the cylinder for failure criteria. Because in static analysis it is impossible to check the composite for safety margin:
And here I have such an error. What is the reason? Thank you.
June 14, 2023 at 2:57 pm
Govindan Nagappan
Ansys Employee-
June 14, 2023 at 6:21 pm
javat33489
SubscriberThanks for the answer. Yes, I figured out the play type. And I have the following error regarding the destruction criteria, as you said
But how do I find these parameters for a new composite? I made it in the material designer and now it should have new destruction parameters. The material designer can determine them for me on the new resulting composite?
June 15, 2023 at 6:55 pm
javat33489
SubscriberHELP. PLEASE.
4468
2957
1427
1322
