February 9, 2022 at 10:07 am
AleksandrZ
SubscriberHello,
I changed something in the simulation settings and tried to run the simulation, and after that Lumerical shut down with error message:
February 9, 2022 at 11:44 pmGuilin Sun
Ansys EmployeeIt seems "invalid vectorsubscript " is a system error. Please google it. You may need to install the system fix.
I would suggest that you restart your computer, and see if it works. Or reinstall the software.
Please let us now if the problem still exists.
- Error on Lumerical device
3778
2575
1825
1242
598
