the radial force and the tangential force in PM motor
    • Peter8415
      Hello,Is it possible that the radial force of the rotor is less than the tangential force when the permanent magnet motor is loaded?
    • Navya C
      Hi @Peter8415 Generally, the radial force is greater than the tangential force.
      This question does not belong to simulation or usage of Ansys softwares. So, I can not conclude on that.
      You may need to consider running some simulations with different rotor-stator configurations to find out the results.
      Regards Navya
