Preprocessing
Preprocessing
the relation between pinball and meshing size
    • Ruan
      Hello, I have a question on the relation between pinball and meshing size. Should the meshing size of contact pair always be smaller than the pinball? Hoping to get your help.
      Pinball?
    • Keyur Kanade
      are you asking circles at the mouse cursor
      the inner circle is defeaturing size
      circle after than is min size
      circle after that is max size
      Keyur
    • Ruan
      As shown in the following figure, what I mean the "Pinball" is the radius defined for ANSYS Workbench to search for contact and target elements.
    • Aniket
      Please check:
      3.9.12.2. Defining the Pinball Region (PINB) in contact technology guide.
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/ans_ctec/Hlp_ctec_realkey.html%23strdetpi5jla072099
      Please check first link in my signature block to open the link above.
      -Aniket
    • Ruan
      Thank you so much for your kind help, I will read the materials you shared.
Viewing 5 reply threads
