December 2, 2019 at 7:13 pm
vsmlingam
SubscriberHi friends: i encountered a new error in Ansys 2019 R2 - While solving the simply supported beam problem - to find out Shear force & Bending moment analysis -
It says - error of The requested database is not available. the Enable command is ignored - I attach an error image snap below - kindly anyone helps me to solve this issues
December 11, 2019 at 2:16 pm
Rohith Patchigolla
Ansys EmployeeHello,
MISC results (SMISC, NMISC) are not stored in the result file (file.rst) by default.
To do a sanity check, please re-solve the model with below command before SOLVE command, and try your steps again.
OUTRES,ALL,ALL
Best regards,
Rohith
December 11, 2019 at 6:08 pm
vsmlingam
SubscriberDear Rohit,
Thank You - Now its worked - I got stress result
December 12, 2019 at 9:06 am
Rohith Patchigolla
Thanks for your reply.
As the issue is resolved, please close this thread as solved.
Best regards,
Rohith
December 31, 2019 at 7:53 am
shahdil
SubscriberThe requested S command is not available.The PLESOL COMMAND is ignored.
when i try find von misses stress of the beam problem the above error occur
January 2, 2020 at 9:30 am
Rohith Patchigolla
Ansys EmployeePlease try issuing /eshape,1 command
May 5, 2020 at 4:58 pm
m3rkm
SubscriberHello,
if the same error occurs ( ETABLE command ignored) on ANSYS 2020R1, what should i do to fix it??
May 6, 2020 at 7:21 am
Rohith Patchigolla
Ansys EmployeeDid you have OUTRES,ALL,ALL?
If yes, please provide more information.
August 23, 2020 at 7:46 pm
Marco_Caiza
SubscriberBuenas tardes. tengo este mismo problema en la version 2020 R1, y quisiera saber como solucionar mi problema de comando ETABLE ignorado n -
September 9, 2020 at 11:49 am
Lina_37
SubscriberAfter assigning command outres,all,all i still having.the database is not available.The ETABLE command is ignore. What should i do? n -
October 22, 2020 at 6:10 am
Pryalen_Chhoeur
SubscriberI tried to do OUTRES,ALL,ALL, it shows me another error message: OUTRES is not a recognized POST1 command, abbreviation or macro. What should I do?n -
December 3, 2020 at 3:24 pm
ASTODIAOLO
SubscriberI have the same problem with the 'ETABLE COMAND' with the 2020R2 version, any advise?. -
January 27, 2021 at 6:11 pm
maggie_wang
SubscriberI have the same problem after tape OUTRES,ALL,ALL, it shows me another error message: what should I do ? n -
February 14, 2021 at 7:25 pm
luismgonzalezg
SubscriberMaybe I am late for this topic but I found a solution in a different posting. I am currently using Ansys Student 2020 R2. This is the link The requested database is not available. the ETABLE command is ignored. ? Ansys Learning ForumnBest Regards,nLuis -
August 1, 2022 at 10:38 am
manarshhjot.singh
Subscriber@luismgonzalezg Can you share the link
September 13, 2022 at 9:30 am
sadaqathussayn
SubscriberHey everyone i also have the same problem. i am using Ansys R19.2 When i tried to apply stresses (Von Misses), it showed this error "The request data S is not available. The PLNSOL command is ignored" And when i tried to import this Ansys file into UM (Universal Mechanism) software to create a bridge.rst file, it showed this error: "Inadmissible DOF constraint UX found in node 1203. Remove all DOF constraints and repeat the calculation" I have tried all possible ways but the error is still the same. In this regard, suggestions are required. Thank you very much.
3351
2471
1310
1018
