June 20, 2022 at 10:23 am
ranshh
Subscriber -
June 23, 2022 at 6:31 pm
Kyle
Ansys EmployeeHello ranshh,
There are some linear electrical elements you can use to create filters out of circuits like this, but because they are linear their properties can't be voltage dependent. I think the closest element to this type of circuit would be the "Voltage dependent low pass (LP) RC filter" element, which has a bandwidth that depends on the input voltage. This element could have a response similar to this circuit, if you can calculate the bandwidth as a function of the applied voltage for this circuit.
- Error on Lumerical device
3744
2573
1815
1236
594
