The result file cannot be opened
    • Sonson
      I am facing this error in a different way as other previous post.
      I run a simulation, i.e. static analysis and everything goes fines, files are saved in the folder and I can postprocess. However, if I run a second simulation, another static analysis in a linked component it deletes the files for the previous analysis. A message saying:
      An error ocurred when the post procesor attempte to load a specific result.
      Current result file may not contain request result data
      The result file cannot be opened.
      Which makes sense because the folder is being cleared by Ansys when I run the second simulation.
      I have tested several wbx files and it happes with all of them
    • Sonson
      For those who find it useful in the future.
      I solved the problem eliminating the folder: C:\Users\XXXX\AppData\Roaming\Ansys
    • Karthik R
      Administrator
      Hello Thank you for letting us know! And glad you were able to resolve it.
      Karthik
