The results file (file.rst) is not available for the NSET option on *GET command.
    • SicParvisMagna
      Hello everyone!
      I am trying to extract displacement and force values of a plate exposed to a horizontal displacement while being constrained from the bottom in UX, UY, UZ. The issue is that when I select SHELL181 as the element type, with all its default settings, I get the following error (see below). However, if I change the element to SHELL41, this issue does not occur. But I need to use SHELL181 for my project. Anyone knows why this issue occurs? Thanks in advance!
       *** ERROR ***                           CP =    1061.047   TIME= 19:127
       *GET command.  The requested *GET data cannot be retrieved.
Viewing 0 reply threads
