Photonics
Photonics
The results from the individual simulations of ‘::model::R::P’ could not be conc
    • gauravs3
      Error help :The results from the individual simulations of '::model::R::P' could not be concatenated : I am trying to run sweep on a model and I would like to plot the power vs sweep parameter for all the runs. I found an example on Ansys form that does the same for saving transmittance instead of power. When I use the files to save power I get the above mentioned error. I would appreciate if someone can help me fix this.
    • Guilin Sun
      I guess this is FDTD, right? what parameters you swept? do they affect the frequency? Usually sweeping geometry does not lead to change of power dimension or transmission.
      Please open the first and the last sweep files (or other distinct files) and check the result dimensions.
      BTW: if it is linear optics, no need to store the Power. Instead, the transmission is sufficient, since the transmission is the real part of power divided by source power.
      • gauravs3
        Thank you for your reply,
        My sweep parameter is the thickness of my film. I am trying to simulate thin film interference and the power changes with my thickness. I can take transmission for now but eventually I need to take into account the imaginary part of the index of my film (which is absorption) and that where I will need the actual power. I am running a 2D Simulation and the power dimension are the same for all my sweep files.
