September 27, 2017 at 11:19 am
admin
Ansys EmployeeThis is the expected behavior: Working with SpaceClaim interactively you will need to expand the corresponding Volume component in the structure tree, then right click on the Volume body and select "Update Volume Body as Created". Alternatively, in a Workbench project, changing the corresponding parameter in the parameter manager and updating, for example, the meshing component (or design points or the whole project) will result in an automatic update of the extracted volume.
admin
Ansys EmployeeI am changing one driving dimension in SpaceClaim. The solid geometry is updated but the fluid volume (created by Volume extract) is not updated.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2156
1359
1150
462
