March 12, 2021 at 5:07 pm
c.manquepillan01
SubscriberHello, my name is Carlos, my English is not very good so excuse me if you don't understand much. At the moment I am doing my degree project that consists of the modeling of a metallic connection subjected to controlled displacements at the outer edges of the beam. In summary, the connection node is modeled with solid185 elements in order to see where the greatest distortions are generated while the other elements are modeled with beam188 elements.
March 15, 2021 at 11:58 am1shan
Ansys Employee,nHave you used a connection between solid and beam elements? Solid elements have only 3 degrees of freedom (3 translation) per node while beam have 6 degrees of freedom per node (3 translation + 3 rotation). You may check to know how to connect beam to solid elements. Also check this out for a detailed discussion on why solid elements have 3 dofs per node https://forum.ansys.com/discussion/22288/why-do-we-need-to-restrain-both-the-translational-and-rotational-dofs-to-avoid-rigid-body-motion. nViewing 1 reply thread- You must be logged in to reply to this topic.
2600
2088
1319
1108
459
