March 1, 2022 at 11:49 pm
MohammedMeqdadi
SubscriberI am using ANSYS 2021/R2 Student edition to simulate RC beam and received the following error message
The solver engine was unable to converge on a solution for the nonlinear problem as constrained. Please see the Troubleshooting section of the Help System for more information.
How I can solve this error
Thank you
March 2, 2022 at 7:24 amSaumadeep
Try the recommendations mentioned here - The Solver Engine was Unable to Converge (ansys.com)
Regards, Saumadeep
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
March 2, 2022 at 8:01 amErik Kostson
Ansys EmployeeHi Also the below shows a recommended way of simulating RC structure (slide 10 shows for the Menetrey-Willam model a setting to help with convergence):
Thank you
Erik
March 9, 2022 at 2:42 pmMohammedMeqdadi
SubscriberI use the Menetrey-Wiliam model a setting but new error coming
An unknown error occurred during solution.Check the Solver Output on the Solution Information object for possible causes.
I use in Solve Process Settings Number of utilized cores 2 and on the Home tab, I untick the 'distributed' option
but still there is error as per the attached picture
Please help to solve the problem
Thank you
Mohammed Meqdadi
2656
2120
1347
1118
461
