The solver output file has exceeded the maximum size and will not be displayed here.
    • sebanac
      Need help,
      Ive done with APDL command and run the solve process,
      but I found this result in my solver output.
      Below attached also my SOLID65 APDL command, the default (I got from drDalyO version and it works) and my own edited command.
      Thanks for your help.
      No automatic alt text available.
    • peteroznewman
      nRight click on the Solution branch in the outline and Open Solver Files Directory. In there is solve.out which is the file that is too large to display. You can search that text file for the word error.nn
    • sebanac
      FOUND SOLVE.OUT HOW CAN I OPEN THIS FILE??n
      Try using the DOS command top and tail. Assuming it's human readable then have a look in Wordpad or the like. nMoving to Structures. n
Viewing 3 reply threads
