Discovery Import
Discovery Import
The spaceclaim – a different behavior – Constraint based sketching
    • l.janicek
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      when I have enable "Constraint based sketching, I can't do use the sketching functions in the 3D mode and I can't do use the Equation in the sketch mode too.
      You can see the described behavior in the video.
      Could you fix the problems, please?
      Thank you, Lukas
    • Subashni Ravichandran
      Hello Lukas Please select 'Enable 3D Sketch' option in the Sketch tab to be able to sketch in 3D mode. Equations option is available on the Design Tab. Although you will see only 3D Equations while the Constraint-based sketching is on. Turning off Constraint bases sketching will populate 2D equations as well.
      • l.janicek
        Hello Subashni
        many thanks for your answer.
        Could you add the function 2D equations to the development, when the constraint based sketching is enable?
        Thanks again, Lukas
      Lukas We thank you for sharing your feedback. We will share your idea/input with the product development team.
