the stiffness matrix of a beam element do not match with the computed result
    • 567
      this are apdl commands
      finish
      /clear
      /PREP7
      /NUMBER,-1
      /VIEW,1,1,1,1
      /ANG,1
      ET,1,BEAM188 ! BEAM
      SECTYPE,1,BEAM,CSOLID
      SECDATA,0.005
      MP,EX ,1,6.9E10
      MP,PRXY,1,0.3
      MP,DENS,1,2700
      zl=1
      N,1,-1*zl,0,0
      N,2,0,0,0
      TYPE,1
      secnum,1
      MAT,1
      E,1,2
      /SOLU
      ANTYPE,2
      MODOPT,LANB,10
      MXPAND,10,,,0
      SOLVE
      /AUX2
      FILE,file,full
      HBMAT,stiff,txt,,ascii,stiff,yes,yes
      HBMAT,mass,txt,,ascii,mass,yes,yes
      The exported stiffness matrix is shown in the following diagram
      ansysstiffness:
      The stiffness matrix is calculated as
      The calculation result of ansysstiffness(2,2) does not match the formula
      i do not know why!
      thank you very much;
    • Mike Rife
      Hi 567
      Here is a hint: what beam theory does MAPDL use and is it the same as what you are comparing to....?
      MAPDL beams are based on Timoshenko beam theory.  Whereas the stiffness matrix shown is based on Euler-Bernoulli beam theory.  Timoshenko accounts for shear deformation and rotary inertia effect (that E-B does not), but the resulting beam stiffness is slightly lower than E-B theory.
      Mike
