June 28, 2019 at 3:04 am
suraj9735
SubscriberWhat does this error mean in Mechanical workbench? And how to fix it?
*** ERROR *** CP = 2295.500 TIME= 10:46:45
The value of TEMP at node 271478 is 1598162.6. It is greater than the
current limit of 1000000 (which can be reset on the NCNV command).
This generally indicates that there are no temperature constraints or
convections applied.
*** MESSAGE CONTINUATION ---- DIAGNOSTIC INFORMATION ***
If one or more parts of the model are held together only by contact
verify that the contact surfaces are closed. You can check contact
status in the SOLUTION module for the converged solutions using
CNCHECK. -
June 28, 2019 at 3:20 am
SubscriberPlease reply with images inserted to explain your model. What are you trying to simulation.
Please show images of the geometry, material properties, boundary conditions and the mesh.
3744
2573
1809
1236
594
