August 8, 2017 at 1:19 pm
banghuazhao
SubscriberWhen we use ANSYS ACT in DesignModeler, we can use API to create primitives. Those primitives become the bodies. Is there a way to change the bodies' name before or when we add those bodies to feature.
For example, I want to create a square pack microstructure. Is there a way to change and the name of fiber and matrix? The codes are following:
ExtAPI.Log.WriteMessage("Generating Square Pack Microstucture 2D...")
# Unit Length of the SG
L = 1.0e3
# Collect the volume fraction of the fiber
volume_fraction = feature.Properties["Volume Fraction of Fiber"].Value
# Calculate the radius of the fiber
radius = L * ( volume_fraction / math.pi ) ** (1./2.)
# Empty SG (array) to collect the entities generated
SG = []
# Some useful builder
primitive = ExtAPI.DataModel.GeometryBuilder.Primitives
operation = ExtAPI.DataModel.GeometryBuilder.Operations
# Created matrix
sheet_square = primitive.Sheet.CreatePolygon([L/2., L/2., 0., -L/2., L/2., 0., -L/2., -L/2., 0., L/2., -L/2., 0.]).Generate()
wire = primitive.Wire.CreateArc(radius, [0., 0., 0.], [1., 0., 0.], [0., 0., 1.]).Generate()
sheet_circle = operation.Tools.WireToSheetBody(wire)
matrix = operation.CreateSubtractOperation([sheet_circle]).ApplyTo([sheet_square])[0]
# Create fiber
fiber = operation.Tools.WireToSheetBody(wire)
# Create Part
part = operation.Tools.CreatePart([fiber, matrix])
part.Name = 'Square Pack Microstucture 2D'
SG.Add(part)
# Add resultant entities to feature
feature.Bodies = SG
# Assign material type to the entities. Different options are Add, Cut, Freeze
feature.MaterialType = MaterialTypeEnum.Freeze
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2156
1359
1150
462
