March 20, 2021 at 11:37 am
akoral19
SubscriberHi,
I'm trying to simulate the "Inverse design of a Y-splitter topology optimization" by changing the given pixel sizes to 20 nm to 50 nm. But I'm receiving the following error. How can we solve this error?
March 22, 2021 at 5:36 pmTaylor Robertson
Ansys EmployeeHello akoral19,nnThis error is because the bounds variable needs to be an array of tuplets the same length as the parameters, with each tuplet defining the min and max values that each parameter can take. The simplest way doing that is to use the same bounds for each tuplet and multiply by an integer. Then the geometry function, initial parameters, and bounds are passed to the lumopt geometry classnnbounds = [(0.2e-6, 1.2e-6)] * initial_points_y.sizennpolygon = FunctionDefinedPolygon(func = splitter,n initial_params = initial_points_y,n bounds = bounds,n ...March 23, 2021 at 11:03 amakoral19
SubscriberThank you for your quick answer but I could not find the part that the bounds parameter defined. Can you please tell me where I can find it?nViewing 2 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2706
2142
1355
1144
462
