March 19, 2021 at 3:16 pm
pedrocarneiro
SubscriberIn 2D thermal steady state analysis in Workbench, anyone knows why Ansys create additional elements when you apply a heat flux or heat flow in a line?nAnsys creates this new element and after this gives error in the solution because creates a four node element with a non-existing node...n -
March 19, 2021 at 4:44 pm
pedrocarneiro
SubscriberI changed from workbench to mechanical and used the surf151 element and it seems to be working better than workbench.n -
March 23, 2021 at 11:49 am
1shan
Ansys Employee,nCould you elaborate the issue along with images. You applied heat flow BC to an edge of a 2D surface body and got an error?.Regards,nIshan. n
Trending discussions
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
