Thermal Analysis by Fluent
    • m.yaghini
      I want to do a thermal analysis of solar cell. I need to have both Heat Flux and Convection as the boundary conditions on the top surface of the cell at the same time, but I can only use one of them, heat flux or convection!
      What should I do to have the both boundary conditions at the same time?
      Thanks
    • peteroznewman
      You should improve your understanding of heat transfer basics.
      Convective Heat Transfer >  q = h(T - Tb)
      where  q = heat flux
                  h = film coefficient
                  T = surface temperature
                  Tb = temperature of bulk fluid on surface.
      Do you see that convective heat flux depends on the surface temperature T?
      A heat flux boundary condition means the value of q is a constant, regardless of the surface temperature T.
      It is mathematically impossible to have both a convection boundary condition and a heat flux boundary condition on the same surface.
      If you know the film coefficient, h, you could use Steady State Thermal analysis instead of a Fluent Model to simulate the convective heat transfer.
