July 14, 2019 at 3:01 pm
hassam
SubscriberI am trying to validate my analytical results using ansys model.
I have used following equation for thermal analysis to generate stress in a composite cylinder
Parameters for analysis are given below. I have used Fourier equations to find out the temperature at the outer radius of inner cylinder as 60 C.
Inner cylinder
units
Outer cylinder
units
Inner radius
5
mm
inner radius
13
mm
Outer radius
13
mm
outer radius
25
mm
Elastic Modulus
234000
Mpa
Elastic modulus
120000
Mpa
Posission ratio
0.44
poission ratio
0.34
Density
8.45
g/cm3
density
4.45
g/cm3
CTE
1.28E-05
C-1
CTE
9.80E-06
C-1
Inside Temperature
120
C
Inside Temperature
60
C
Outsiside Temperature
60
C
Outside Temperature
20
C
The analytical solution is given below
Ansys model
After i apply the above boundary conditions i get the following temperature distribution
I dont understand why the second cylinder shows a constant temperature change?
I want to know if my approach is right to solve this thermal problem and get the desired results for the analytical problem mentioned above
July 15, 2019 at 10:39 am
Ansys EmployeeCheck the contact pair settings between the two bodies: I suspect you're not passing heat from the brown-ish zone to the blue-ish one.
3744
2573
1821
1236
594
