June 1, 2023 at 7:00 am
Steven Wu
SubscriberHi Guys
I want to simulate the cooling systerm design for magnetic coupling in pumps using CFX. In CFX-pre I set inlet/outlet pressure, heat flux on outer sylinder surface.
And I want to get the cooling flow out of outlet and tempreture on outlet surface.
Simulation can run but the iteration is not convergent after several steps, no matter in steady or transient run.
Do you have any suggestion for this such kind cases? Very appreciate.
June 1, 2023 at 8:05 am
C N
Ansys EmployeeHello Steven,
I recommend you to try modifying the TimeScale value (In "Solver-Control" option) and check it. I am attaching a best practice tutorial file regarding pump in cfx. Please refer to these links for appropriately setting up the case.
(60) ANSYS CFX: Design and Analysis of a Pump Impeller - Part 1 - YouTube
(60) ANSYS CFX: Design and Analysis of a Pump Impeller - Part 2 - YouTube
Hope this solves your problem.
Thanks,
Chaitanya natraj
June 1, 2023 at 8:28 am
Steven Wu
SubscriberDear Chaitanya
Thanks for your suggestion, I change TimeScale to 1/rpm instead of auto timescale, then it works.... Thanks a lot...
BTW, I'm very familar with how to simulate pumps using CFX, but this is my first time to consider thermal transfer, do you have any best practice cases about thermal analysis using CFX/Fluent?
Best regards
Steven
June 1, 2023 at 9:00 am
C N
I am glad that the suggestion on time scale worked. I will look into it and send you the files if it is available .
Thanks,
Chaitanya Natraj
7742
4502
2969
1449
1322
