March 20, 2023 at 1:33 am
pb771
SubscriberHi, I was exploring the PIN MZ modulator example (https://optics.ansys.com/hc/en-us/articles/360042327854-PIN-Mach-Zehnder-modulator) example and I found that the thermal impedance of the eletrodes are set as 1000 m2K/W
I wonder why is this value so large given that alumium has a large thermal conductivity (326 W/mK)? Thank you!
March 21, 2023 at 4:38 pm
Guilin Sun
Ansys EmployeeCurretly this example https://optics.ansys.com/hc/en-us/articles/360042327854-PIN-Mach-Zehnder-modulator has only CHARGE simulation.
Large thermal impedance is usually meant to be very long geometry.
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5340
3345
2471
