thermal non-equilibrium modeling of porous material
    • srnayak97
      Hi.
      I am trying to model for heat transfer and fluid flow in porous media. I want to use a non-isothermal condition between solid and fluid within the porous body. But as soon as I choose the thermal non-isothermal option, next time setup shows up a fatal error (segmentation) and simulation does not start. Can anybody help me in this regard?
      Thanking You
      Soumya
    • DrAmine
      Release you are using? Screenshot of porous panel before conforming.
    • srnayak97
      I don't understand what you are asking for. Can you please clarify?
       I want to simulate a heat exchanger filled with a porous material. I will also consider the wall of the exchanger. The thermal interaction between the fluid and porous body is non-equilibrium and will be coupled through area density and heat transfer coefficient.
      Kindly help me in this regard
      Thanking You
      Soumya
