Thermal radiation
    • Sahithi Pampatwar
      Hello, I am working on validation of thermal radiation and I am using steady state thermal analysis in workbench.
      I wanted to apply radiation to an enclosure along with convection inside it, I used commands to remove bulk temperature constraint as follows:
      /gopr
      /prep7
      nsel,none
      N
      FLUID_TEMP=ndnext(0)
      cmsel,s,For_Convection
      esln
      esel,r,ename,,152
      *get,AR80,elem,elnext(0),attr,type
      keyopt,AR80,4,1
      keyopt,AR80,5,1
      emodif,all,-5,FLUID_TEMP
      /solu
      allsel,all
      cmsel,all
      But it is showing error as enclosure type PERFECT was incorrectly chosen. (I have selected all the surfaces for surface to surface radiation).
      I would be happy for the help
    • Sahithi Pampatwar
      I have used the same commands previously and it worked. The only difference is slight change in the geometry
    • Nanda Veralla
      Hello Sahithi,
      Thanks for sharing the solution with the community. I'm sure it will help other's who are facing similar challenges.
      Best,
      Nanda
