March 31, 2022 at 6:25 am
ljuenemann
SubscriberCan I extract the thermal resitance and capacitance from Icepak after defining the geometry and material? So that the result would be a thermal network?
Thank you.
April 21, 2022 at 10:05 pmNikhil Tamhankar
Ansys EmployeeHi ,
Just to double check, do you mean like a R C network for transient cases like a Foster or Cauver network ? Do you have some sort of an explicit CAD geometry of the package with all the parts and materials ?
April 22, 2022 at 2:27 pmljuenemann
SubscriberHi I mean Foster and Cauver networks. I have an explicit CAD geometry with all parts and materials. I want to extract the Foster or Cauver network from this geometry.
Thanks
Lennart
April 28, 2022 at 5:01 pmNikhil Tamhankar
Ansys EmployeeHi Unfortunately, there isnt a direct feature or macro to extract the R C networks from the geometry currently in Icepak. However, Icepak and Twin Builder / Simplorer can be used to perform the large number of trials and simulations needed for curve fitting required for the R C network creation.
June 27, 2023 at 6:52 pmViewing 4 reply threads- The topic ‘Thermal resistance Icepak’ is closed to new replies.
Trending discussions- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3153
1680
1474
