Thermal Simulation of MOSFETs
    • sder
      I'm trying to run a thermal simulation of a PCB and I'm especially interested in the MOSFETs. For the DC IR Drop Analysis I replaced the MOSFETs with resistors which worked well. Then I start the Icepak Simulation in SIwave. When I do the Simulation Setup and check the Box "Include" (Component Configuration Tab) of the new added resistors (which are supposed to approximate the thermal behavior of the MOSFETs), I get temperatures of over 200°C which is far too high. I'm not sure what is the issue here.
      Thank you
    • Satyajeet Padhi
      I think your boundary conditions may not be set correctly. If the heat generated is not dissipated properly then the temperatures obtained can be higher.
    • sder
      Hi thank you for your reply. I'm not sure which boundary conditions that might be though? What exactly do you mean? (I'm simulating with 12V and 250A)
      Thank you!
    • sder
      Also when I want to include the resistors in my Icepak simulation I cannot change the power dissipation of them and it seems a bit too high there already. I'm not sure if I even need to include the resistors again, since they're already included in the DC IR Drop analysis and Icepak is working with that data. So maybe I would be including them twice?
Viewing 3 reply threads
