April 14, 2023 at 3:11 pm
Chenxi
SubscriberIs there a way to turn the thermal solver on for some parts/elements and off for others in a model? Or every part need to be involved?
Thank you.
April 14, 2023 at 5:03 pm
Andreas Koutras
Ansys EmployeeHello Chenxi,
If you want some parts to not take part in the thermal solution in LS-DYNA, define BOUNDARY_TEMPERATURE for all the NODES belonging to the PARTS to be removed. You can set the temperature to anything. Temperature=0 is a reasonable choice. These nodes will then be constrained out of the problem. You will still need to assign a thermal material to these parts though.
April 15, 2023 at 1:06 am
Chenxi
SubscriberThank you.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
5242
3299
2469
