October 31, 2018 at 11:24 pm
Jedi_USC
SubscriberWhen I run 2 thermal simulations and change a boundary condition, for example, the color red = 40 deg changes from color red = 30 deg.
How can I keep the color scheme to be consistent between different simulations. I want to more easily compare between simulations using the colors.
November 1, 2018 at 4:11 am
Keyur Kanade
Ansys EmployeeHello,
You can check 'Colormap Options' in contours panel.
You can also try to switch of Auto Range.
Keyur
November 1, 2018 at 4:43 pm
Jedi_USC
SubscriberCan you attach a screenshot of the menu, Keyur?
I can't find "colormap options" or "auto range". I have Ansys 18.2.
November 2, 2018 at 5:55 am
Keyur Kanade
Ansys EmployeeAre you running Fluent or ANSYS?
November 7, 2018 at 11:02 am
Karthik R
AdministratorHello,
If you are using steady state of transient thermal to model your problem, you can simply click on the top and bottom of the color legend (on the min and max values display). This should allow you to modify these min and max values. You can adjust the values according to the legend you want Ansys to display.
If you are working with Ansys Fluent, please use the 'color map' options, as per Keyur's advise.
Thanks,
best regards,
karthik
November 7, 2018 at 7:04 pm
Jedi_USC
SubscriberI am running steady state thermal.
So I need to manually set the min and max values of each simulation? -
November 8, 2018 at 8:37 pm
Karthik R
AdministratorHello,
ANSYS steady state thermal will certainly give you an automatic range on your legend. But if you are planning on changing it, you could change the min and max values manually. This is allowed in the tool and is certainly one way to achieve your results.
I hope this answers your question.
Thank you.
Best Regards,
Karthik
2688
2138
1351
1136
462
