August 10, 2017 at 6:44 pm
svecchi
Ansys EmployeeA steel bar is placed between two walls with one end rigidly fixed to the wall while the other end is 2mm away from the wall. The bar is then subjected to an increase in temperature of 100 degrees Celsius. This tutorial will utilize ANSYS AIM to find the maximum stress in the bar. See the attached file for a tutorial on this problem.
- I’m a starter
- YouTube tutorial files
- Fluid Flow – Lid Driven Cavity
- Thermal – Heat Conduction in a Cylinder
- Fluid Flow – Turbulent Flow Over a Backward Facing Step
- Fluid Flow – Taylor-Couette Flow between Rotating Cylinders
- The project files directory doesn’t exist
- Magnetics-Permanent Magnetic Circuit with Air Gap
- Process ‘3dedy’ terminated abnormally. It may have run out of memory or could have been killed by..
- vibration
2706
2146
1357
1150
462
