Thermodyanamic properties from Fluent
    • jeong
      Hello
      I am trying to model cascade flow, but wondering how I can compute isentropic enthalpy and specific heat capacity ratio from Fluent? I have set Cp as polynomials and density as ideal gas.
      Kind Regards
    • RK
      You can compute from the Reference Values tab. Go to the reference values tab and under the Compute from drop down list, choose which boundary you want it to be calculated from. Let me know if you are able to get it.
      Rahul
    • jeong
      Hello Rahul
      Thanks for the information. It looks like there is no isentropic enthalpy. I also need it as output parameter, so it will be nice to have some way to calculate it, maybe in report definitions. Is this possible? Is the total enthalpy deviation something related to isentropic enthalpy?
      Kind Regards
    • DrAmine
      Check the related section for turbo post processing. It also shows which formula to be used.
    • jeong
      Kind Regards
Viewing 4 reply threads
