TAGGED: ls-dyna, mechanical, structural, structural-mechanics, structure
May 2, 2022 at 4:13 pm
Krishna Prasath
SubscriberMay 6, 2022 at 1:30 pmAniket
Ansys EmployeeAnsys staff can not download any files on the forum, so if you want to reach a larger audience to get answers from, please insert inline images describing your problem.
-Aniket
May 20, 2022 at 11:50 pmReno Genest
Which TSHELL formulation are you using? I am not sure if all TSHELL formulations are available for battery simulation, but formulation 3, 5, and 7 use the full 3D stress update and may give better results when the thick shell is loaded in the thickness direction.
I could not access the paper you reference, but I found the following one which I think is very similar?
Reno.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3744
2570
1787
1236
594
