This project contains data that requires software modules that are not installed, see Details below.
February 9, 2022 at 7:58 pm
Harrrrry
SubscriberFebruary 10, 2022 at 5:05 amKeyur Kanade
Ansys EmployeeHave you installed new version or something else? Error shows that you have some modules installed previously like CFX, Fluent or ACT etc. when you have saved the files. Now you are trying to open it and it can not find those modules. Please make sure that you have installed all the modules as you had done previously.
Regards Keyur
February 10, 2022 at 7:59 pmHarrrrry
SubscriberI did not make any changes to the program or the file. After a long time, I encountered this error when I opened this file. I don't get this error message with other files. How can I reinstall the modules?
Thank youFebruary 11, 2022 at 9:50 amRob
Ansys Employeemoved to installation. Which version of the software are you using (version ID, eg 2021R2), and is it Student or from the campus system? You say it's not working after "a while", how long a while?
February 11, 2022 at 11:13 amHarrrrry
SubscriberThe version I am using is not student. 19.2 version. I opened the same file about 2 weeks ago. It does not give any errors in other files. Thank you.
February 11, 2022 at 11:45 amRob
Ansys EmployeeThanks. Other than not working, what is different about this file?
February 11, 2022 at 11:58 amHarrrrry
SubscriberThere is no difference. I opened and worked on it two weeks ago and now I get an error message when I open it. I cannot open the file.
February 11, 2022 at 12:02 pmRob
Ansys EmployeeSo the file is identical to the others? Can you check the licence file, if you're linked to the campus network has that changed?
February 11, 2022 at 4:01 pmHarrrrry
SubscriberNo, it's not the same. A different project file. I opened and used it two weeks ago. But now I'm getting the error I posted above. I will check the license. Thank you for your help. Sorry for disturbing you.
February 11, 2022 at 5:16 pmRob
Ansys EmployeeIt's no bother, don't worry about that.
February 26, 2022 at 3:36 pmHarrrrry
SubscriberRe-installing fixed it. Thank you
Viewing 10 reply threads- You must be logged in to reply to this topic.
Trending discussions- Error with workbench SceneGraphChart
- Workbench error
- Workbench not opening
- License Error
2656
2120
1347
1118
461
