December 22, 2022 at 5:22 am
paul
SubscriberHello,
When inserting a standard hole with thread, SpaceClaim picks the lowest face as measure point, while i did not specify this. Could this be looked at?
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
December 22, 2022 at 11:05 pm
Charudatta Bandgar
Forum ModeratorLet me check if this is a bug, Paesc
I will get back to you.
Regards.
December 23, 2022 at 7:20 am
Charudatta Bandgar
Forum ModeratorHello Paesc
I have filed a bug ticket, 760787. Will let you know when I hear more.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7798
4508
2979
1449
1322
