September 19, 2023 at 6:41 am
BALA
SubscriberHi All,
I am having three plate which joined or holded by a single bolt as shown in figure, in case if i want to use a beam connection or fixed joint then how can i connect these plate three using these coonection. as far as i know we can connect two plate easily, can we select two surface or curves in mobile scope .
September 21, 2023 at 12:36 pm
Ashish Kumar
Forum ModeratorHi,
Via beam connection or a fixed joint constraint top and bottom plates. Let the center plate be held by friction and if needed define cylindrical constraint in the hole through which the bolt passes.
Ashish Kumar
4432
2949
1422
1322
