August 19, 2019 at 7:37 am
Oelot
SubscriberHi, I need to compute and study a three point bending under displacement control
So I modelise it like this :
it is a simple beam ( box ) of 100mm length and the cross section 16*16 mm
I fixed one cross section with fixed support and the other one (the one with symetry) I put the displacement control :
but my problem is I had too much stress :
Thanks you
August 19, 2019 at 2:31 pm
Subscriber1) You have not created a Symmetry Region, but you can create the effect with the displacement boundary condition on the face at the center of the full length of the beam. That would be to set X = 0, not Free. I assume the beam lies along the X axis.
2) You have not created a roller support at the end of the beam, but a cantilever support by using a Fixed Support boundary condition. Delete the Fixed Support and instead select that face and create a Remote Displacement. Set Y = 0, Z = 0 and Rotation X = 0. This assumes you have created a beam geometry that is 100 mm long for the half length.
3) Optionally, you could slice the beam in half again, and have an 8 mm wide beam, and apply a Z = 0 Displacement boundary condition on that center face to represent the symmetry plane.
August 20, 2019 at 7:28 am
August 20, 2019 at 7:21 pm
SubscriberTo get accurate stress results, you should have more than 2 elements through the thickness top to bottom.
Try using 4 to 10 elements.
What stress did you want?
You can reduce the stress by reducing the Young's Modulus of the material.
August 20, 2019 at 8:21 pm
Oelot
SubscriberI want to see if with a displacement of 30 mm i will reach the yield strength or not, the yield stregth is about 420 Mpa ...
August 21, 2019 at 12:25 am
SubscriberYou have your answer, the maximum stress is > 420 MPa, so this beam has exceeded yield strength at 30 mm of displacement.
August 21, 2019 at 9:13 am
August 21, 2019 at 2:41 pm
2080
1299
1106
459
