September 20, 2022 at 7:33 am
shk1048
SubscriberHi all,
I was trying to run a simulations with THUMS pedestrian model. It is a impact simulation where the vehicle hits the HBM. After the impact of the head with the components. I received negative volume error. I tried to use *Set_segment with part_IO and also tried contact_interior but didnot solve the problem.
Thanks,
Shashank
September 20, 2022 at 10:53 am
Zafar Haider
SubscriberApply Material Erosion to the tissues and Bones. There are number of literature available which shows the strain or stress values where the rupture or fracture occurs in actual cadaveric tests. Use those values.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2616
2098
1323
1108
461
