July 2, 2020 at 8:08 am
Mojgan Ghodrati
SubscriberI am doing a simulation of permanents cylinder magnets. Magnets are axially magnetized (please look at the attached image). The upper magnets were tilted for 2 degree in X direction (constant tilt). Magnets also rotating around Z-axis to calculate torque. Without tilting the created torque in only around Z-axis, but with 2° tilting, torque was also created around Y-axis. I am interested to calculated the tilting stiffness (mN.m/degree). Could you please help me how can I calculate the tilting stiffness (mN.m/degree)?
July 2, 2020 at 10:38 am
Naresh Patre
Ansys EmployeeHello Ghodrati
I am not sure if it's possible to calculate tilting stiffness. Let me look into it and get back to you.
July 3, 2020 at 12:56 pm
Naresh Patre
Just to update you that I have reached out to development team to see if it is possible to calculate tilting stiffness. I may get a response early next week since it's a holiday today in Ansys U.S offices. Thank you for your patience.
July 6, 2020 at 2:55 pm
Naresh Patre
AIM is not exposing tilting stiffness as a direct result type for Electromagnetics problem. This question is being passed on to the Electronics development team which works on Maxwell solver (which is used by in background for solving Electromagnetics problems) to see if any workaround is possible. And for that, they would like to look at the project file that you have. So can you share the archived project file (.wbpz)? I will send you a secure transfer link separately through email for uploading the project file.
July 7, 2020 at 7:36 am
Naresh Patre
Thank you for sending the project file. I have forwarded it to the development team and will let you know their response.
July 14, 2020 at 11:13 am
Mojgan Ghodrati
SubscriberHello Naresh Patre , May I ask you if there is any update on my question regarding stiffness?
July 14, 2020 at 11:42 am
Naresh Patre
Apologies for the delay. I got below solution from the Maxwell developer but I need to check if it is possible in Discovery AIM or not:
The procedure should be like following:
(1) the magnets always rotating with Z axis;
(2) with tilting angle =0, calculate the torque: post processing, and get the RMS value of torque curve
(3) with tilting angle =2, calculate the torque: post processing, and get the RMS value of torque curve
(4) |Tr2-Tr1|/2 is the stiffness
July 15, 2020 at 6:28 am
Naresh Patre
The developer said that the above solution should work with Discovery AIm as well. Please let me know if you face any issues while doing so.
July 21, 2020 at 11:52 am
Mojgan Ghodrati
SubscriberNaresh Patre Thank you very much for the reply, so I should calculate the Root Mean Square of the Torque around Y-axis (in my specific example) for 0° and 2° tilt. Then the tilting stiffness will be [RMS(TY1)-RMS(TY2)]/2, is this correct?
July 21, 2020 at 12:23 pm
Naresh Patre
Ansys EmployeeGhodrati Yes I think so. That's what the developer had suggested.
July 21, 2020 at 12:27 pm
Mojgan Ghodrati
SubscriberNaresh Patre Thank you very much.
3930
2649
1865
1272
610
