Time-averaged streamlines in FLUENT
    • NimaNZ
      Hi everyone
      Would you please let me know how I can draw the time-averaged or time-mean streamlines in the transient solution in FLUENT?
      Note: I don't mean the colormap of the pathline in the pathline option which can be set to mean velocity; I mean the mean flow streamlines.
      Many thanks
    • DrAmine
      You get first of all mean velocities by data sampling, then you patch the velocity field with the mean velocity field and then draw streamlines.
    • DrAmine
      Or you add some more details to better understand your request!
    • NimaNZ
      Thank you for your quick reply!
      I have the Mean Velocity values through the sampling process for more than 50000 time-steps. It is a bluff body in the domain and has vortex shedding on the wake side; the mean streamline will be symmetric; I cannot draw that.
      How can I patch the mean velocity values?
    • NimaNZ
      Thank you so much! found out how to patch the mean values.
      There is still an issue! As the domain has been divided into sub-domains, after patching the values, the streamlines are discrete; is there any way to solve this?
    • DrAmine
      I dunno not understand why patching will result in subdomains.
      If seeing discontinuities you might run a couple of iterations with all urfs set to very low value perhaps that helps.
    • NimaNZ
      Thank you so much for your help; it is really appreciated.
Viewing 6 reply threads
