November 26, 2020 at 5:58 pm
paola_1
SubscriberHi, there is a way to write the time averaged mean data of turbulent viscosity in a UDF? Like I can do with the x velocity with C_STORAGE_R(c,t,SV_U_MEAN)/delta_time_sampled.nnIn particular, I would like to write a UDF to get the spatial derivatives of the Reynolds Stresses - d(uu)/dx, d(uv)/dy, d(uw)/dz - that I write with the Boussinesq approximation.n -
November 27, 2020 at 12:38 pm
Forum ModeratorNo idea, have a look in the documentation and header files to see what's available. Note, the macro may be model dependent. n -
November 27, 2020 at 1:11 pm
DrAmine
Ansys EmployeeNo there is no Svar for that. I remember there is a way via Custom Field Function and but is it not documented and for that reason not supported.n -
November 27, 2020 at 1:56 pm
paola_1
SubscriberThank you.n
- The topic ‘Time averaged turbulent viscosity UDF’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1688
1478
