March 23, 2021 at 9:49 am
MANNAN
SubscriberMarch 23, 2021 at 5:31 pmGuilin Sun
Ansys Employeeyou can use set(set time domain,1); to enable a tab property. One this is enabled, you can set other properties, as you did in the script, such asnset(offset,3e-12);nplease note that the units in scripting are international standard, meter, second, kg etc.nnyou can usen?set; when an object is selected to know all its parametersnorn?setnamed(object_name) to know the parameters for a specific object.nnPlease try and check if all the set results are what you expect.nMarch 23, 2021 at 5:34 pmGuilin Sun
Ansys EmployeePlease note that since the source is a pulse, even through you set the wavelength bandwidth zero, it will still be a pulse, meaning it will radiate em waves in a broadband. nMarch 26, 2021 at 4:21 pmMANNAN
SubscriberThanks a lot it worked nMarch 26, 2021 at 4:28 pmGuilin Sun
Ansys EmployeeThank you for letting me know this! good luck in your project!nMarch 26, 2021 at 6:04 pmMANNAN
SubscriberCould you please further help in regarding the thisx=linspace(-d/2,d/2,N); # x position vectornnfor (i=1:N) {nadddipole;nset(x,x(i)); nset(y,0);nset(z,0);n}nThis code will make a line of N dipoles along the x-axis between length -d till d. with equal spacingnnSuggestions required in making a script that will make a cone of dipole along xz direction with radius r in x-direction and depth along z-axis nnLooking forward to hearing soonMarch 26, 2021 at 10:48 pmGuilin Sun
Ansys EmployeeThe code looks good for me. In order to make the dipoles to be in a cone in xz plane, you will need to change x(i) and z(i) as a cone, and then place the dipoles there. Please try to modify your script.nViewing 6 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2630
2104
1329
1110
461
