time history of temperature averaged across a surface in transient thermal
    • xiaojiangyou
      I'm running a transient heat transfer process in ANSYS TRANSIENT THERMAL module. Is it possible to get the time history of the averaged temperature over a surface?
      Thanks so much for your time and efforts!
      Best
      Xiaojiangyou
    • peteroznewman
      I picked a face in this Transient Thermal to plot the Temperature results. The Tabular Data has the time history of the average for the face.
    • xiaojiangyou
      Hi peteroznewman,
      Thanks sooooo much for your help! I did open the tabular data but I couldn't see the average value. Is it possible that there are some settings I need to make before making the temperature contour?
      Really appreciate it!
      Xiaojiangyou
    • peteroznewman
      Average was added to all results in one of the recent versions of ANSYS. You don't have it in your version. Can you upgrade to the latest version of ANSYS?
    • xiaojiangyou
      Thanks so much again. I'll try update to the latest version.
      Besides, I'm also wondering is there a way to output the time history of each node temperature on that surface? I probably want to weighted average to that surface in the future.
    • peteroznewman
      You can Export the temperature of every node on the face at any specific time of the solution by right click on the Temperature result and selecting Export.
      I know it is possible to write APDL code in a Command object in the Solution branch that will cause a file to be written with every time step, but I don't know the APDL commands myself. Perhaps someone else can provide that.
    • xiaojiangyou
      I see. Thanks so much!
Viewing 6 reply threads
