January 31, 2021 at 4:59 am
Avinaba95
SubscriberI have taken a pipe length 0f 6 cm and diameter of 8 mm. I started meshing with 75 mm .It has already passed around 40 hrs but the meshing has not completed yet.. I am working with Ansys student 2020 r versionnHow long it will take?nOr i have to start again??n -
February 1, 2021 at 6:50 am
Keyur Kanade
Ansys EmployeeIf you have student license, you have size limit 512K cells. If you are using research license then you can create more cells. nYou mentioned 8 mm dia and size of 75mm. This may give errors. nPlease see meshing sizes. nAlso please create a simple box and try to mesh it. Make sure meshing is working and installation is correct. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
5268
3299
2469
