April 22, 2019 at 4:23 am
April 22, 2019 at 6:30 am
Gaurav Sharma
SubscriberHi Keito Yaginuma
The CSV file lists all the time points at which solution was performed. As you might be aware that the time points at which calculations are performed by solver are controlled by substepping under solution progression:
In the example above, only 4 substeps are provided through user specified input. Hence, the output CSV file will have only 4 data points. please refer the attached video that shows the max temperature plot having only four data points corresponding to the each substep.
You can appropriately control the substepping in your analysis to get more data points for the CSV results file.
Thanks & Regards,
Gaurav
April 22, 2019 at 8:22 am
yaginuma.keito.yd
SubscriberThank you, Gaurav_ANSYS
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Unexpected graphics error
- loss of user settings
- Dwg export error
- Can’t see license on online account
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- problem to access on the spaceclaim help
- Unsymmetric result
3694
2564
1765
1234
590
