March 16, 2021 at 2:46 am
JustinN13
SubscriberHello all,
I am trying to simulate the result of friction between a cup wheel and concrete pad, 2 objects only. Cup wheel is ~178 mm diameter imported as a .STEP file, pad is 180 mm * 93 mm:
March 16, 2021 at 11:03 am1shan
Ansys EmployeeHelloArray,nWhat is the error message that you are receiving? You may want to ensure that there is no initial gap/penetration across target/contact face. For this use the Adjust to touch option under Interface treatment. Also, I see that the pad displacement is along the Y axis. Is this correct? The pad should move along the Z axis (revolute joint axis is) in order to touch the disk and create some pressure. Right?nRegards,Ishan.nViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1285
1096
459
