October 5, 2018 at 6:22 am
srnayak97
SubscriberI am doing a transient flow simulation through a pipe. I want to plot the area averaged pressure variation at the inlet. In the xy transient i can select only point.
Thank you
October 5, 2018 at 7:08 am
DrAmine
Ansys EmployeeFirst of all you need to make a report of area weighted average of the pressure at the inlet. Here you need to enable the option write to file. Afterwards you can then plot your pressure along the time in the plot function in Fluent. If you are doing that in CFD-Post you need to create an expression for the weighted average, create a transient chart and here you give the Expression name like TimeAvePres = areaAve(Pressure)@Inlet
October 5, 2018 at 9:36 am
srnayak97
SubscriberThanks a lot. This really helped.
October 5, 2018 at 9:48 am
Karthik R
AdministratorHello,
I am glad that the solution worked for you and you are able to learn and move forward. It would be really helpful if you could mark abenhadj's answer as "Reply". This would accomplish two things:
- It would be of immense help to someone if they have the same question as you had.
- It would help bring closure to this question.
Here are the guidelines for posting on the student community.
Thank you very much for your question.
Best Regards,
Karthik
2524
2066
1279
1096
457
