Time varying Impedance in HFSS
    • jo_t
      Hello, I have an incident beam launched at an antenna that I want to load with a certain impedance that should switch between two values periodically. Is there a way to achieve this? I was thinking about utilizing co-simulation with Circuit, but did not get far.
      Thank you in advance!
    • Dan Dvorscak
      If you are ok using resistive termination as the load here, you can make this work in Circuit by driving a voltage controlled resistor with a pulse source.
    • jo_t
      Thank you for the answer. Could you please provide more detail on how to setup the link between HFSS and Circuit? Ideally, I would want to have a sheet in HFSS and assign an impedance boundary. The value of this impedance boundary should be switched.
